Strungup Posted May 18, 2009 Report Share Posted May 18, 2009 (edited) I will post some pics , here , and Audio samples of my Mic preamps .These will be XLR input x 2 -> 1/8 stereo output , for MD / DAT/ Flash Recorders etc . These preamps will be about 150 US . Without Phantom , you can use any Self powered Condenser Mic ( Has its OWN battery in it ) IE: AKG C1000 , Sony ECM series , Sennheiser stereo mics that are self powered . All Dynamic mics , Shure SM 57, 58 ......... Beyer Dynamics (I Love Beyer mics) A pair of M201 's would sound awesome with this preamp .( For the moment I am removing the Phantom power option , The chip I need isnt available here in Japan for it , I have to find a different circuit ) The Caveat is , at the Moment until I can figure out why , When using a Remote with the RH1 , there is a fair amount of process noise from the Remote . Without the Remote the recording is quite clean Samples ( you can really hear the difference between the RH1 and the Tascam , the RH1 is soo much more airy ) RH1 sample without Remote , sitting outside on the back , with two Sony ECM23F3 mics , at about 3 feet distance from me . The RH1 files were uploaded as WAV , then to Final Vinyl , to trim the end off only no noise reduction at all , then To Switch MP3 Converter to 192( 160 for the ambient so it would fit the upload size) kbs MP3Tascam DR-07 Mic input Test same file Normalized in AudacityThe Tascam was uploaded straight from the recorder , not edits SpecificationsGain= 26 db fixed settingS/N = -88 db ( very very quiet )Power =1 x 9 Volt battery input = XLR balanced , converted internal Balanced to Unbalanced for better shielding and noise rejectionOutput = 1/4 inch stereo connector, use Headphone adapter (Supplied)for 1/8 inch Impedance set for a weak mic input on a recorder , Home Multi Track , or Low Mic Gain on MD , Or Low Mic Gain on Flash Recorder such as Tascam DR-01 , DR-07 etc ) Sharp MD Recorders will benefit greatly from this preamp because I have always found the Sharps to a little noisy , this will clean it right up. Pro Mics ........... With your MD !!I can take Paypal , and will ship wherever from Japan , you pay shipping .Shipping will be by EMS , insured and with tracking number Edited May 19, 2009 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 18, 2009 Author Report Share Posted May 18, 2009 (edited) Even with the remote's backlighting off?Yeah sad to say , the remote was a bust , even tried the 11elk , noise was way less , but still there ( learned that I can adjust the record level from the 11elk !!!!)What I think is , that I may need to use coupling capacitors on the output stage, because the residual voltage from the RH1 mic input . I will experiment with that . I will take it apart , and change a couple things on the circuit . But it sounds really good as it is setup now . The Tascam doesnt quite record at accurate DB levels , so I could actually run a little Hotter on the Tascam , I will try that today .The R50 is what I tested with first ( reasoning , not everyone is using the RH1 ) so an Older MD was first , and actually was a Very good union the first test was about 25 minutes of this and that , and I was really liking what I was hearing . I am not quite done with the design , a couple improvements . but it is quite likable at this stage . Edited May 18, 2009 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
tekdroid Posted May 19, 2009 Report Share Posted May 19, 2009 Guitarfxr,just wondering if there's any possibility of getting a unit like this to run off (lots of) AAs (perhaps with an external 'power pack')? Reason I ask is it's very hard to find 9V rechargeables (and I'm a 'reduce waste' freak who hates throwing out disposables, even if it's once a year). Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 19, 2009 Author Report Share Posted May 19, 2009 (edited) Guitarfxr,just wondering if there's any possibility of getting a unit like this to run off (lots of) AAs (perhaps with an external 'power pack')? Reason I ask is it's very hard to find 9V rechargeables (and I'm a 'reduce waste' freak who hates throwing out disposables, even if it's once a year).If you dont mind the Weight that would introduce ,The box would of course be sized to accept the AA's , but yeah I can build one that way . Rechargeable AA's are 1.2 volts , so your looking at an 8 pack( 9.6 volts) ( 6 pack is only 7.2 volts ) and your battery life would be ........... um how should I say this ..................... About 1 galactic year or so ( provided the AA's dont self discharge before then )Or I could MOD a standard one with a switchable DC Jack , so you can use an external pack , so when you plug in it shuts off the internal battery . Edited May 19, 2009 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 20, 2009 Author Report Share Posted May 20, 2009 Also , I am looking for a "Holy Grail Plus " Reverb Pedal , If you have one , in decent shape ( I dont mind used , as long as it is working good ) I will trade a Preamp for the Pedal . Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 21, 2009 Author Report Share Posted May 21, 2009 (edited) 250 views , and .............. Wiz , I will continue working on the Remote issue , and If I fix that , I will email you . Anyone with a 4 track recorder , You really need one of these . The improvement is substantial . Edited May 21, 2009 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 22, 2009 Author Report Share Posted May 22, 2009 Guitarfxr,just wondering if there's any possibility of getting a unit like this to run off (lots of) AAs (perhaps with an external 'power pack')? Reason I ask is it's very hard to find 9V rechargeables (and I'm a 'reduce waste' freak who hates throwing out disposables, even if it's once a year).Hey Tekdroid , I went to the shop where I buy the goods for these preamps , and They have a box and TWO , poptop AA holders which I can embed in the back of the case nicely Case is 180 MM wide , vs the 150 of the design above , so it isnt that much bigger . But most definately doable . Just let me know The case and Batt packs are a little extra , so I would have to include that in the budget Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 23, 2009 Author Report Share Posted May 23, 2009 I Did a test this morning , of the preamp I put together vs. the Presonus Stereo Blue Tube Preamp . Sony MD4X 4 track , inputs 1 & 2 First from the Presonus , Using my Sony ECM23F3 condenser mic . I had just changed the Tube in the preamp and wanted to make sure it was working , I put a lesser gain tube in it , a 12AT7 , instead of the 12 AX7 , With the AX7 the Presonus is know to be a little noisy when you add the drive into the signal . With the 12 AT7 noise was noticably less , output was better , and gain was smoother . But still some noise . I thought " Hmmm I wonder what this Homebuilt will sound like in comparison ( At this point I had not tried it with the Sony 4 track ) So I switched the cables , and Mic to My Preamp . WOW , what a difference , the Noise level was NO WHERE NEAR the Presonus , way quieter , and good clean solid gain . I will try to post some sample after the weekend , My Family is here so the house is noisy . tuesday I might have some time . But seriously , if you have a 4 track , you need this preamp . Quote Link to comment Share on other sites More sharing options...
Strungup Posted May 28, 2009 Author Report Share Posted May 28, 2009 (edited) Well I tested with the Yamaha Md4 track , and was pleasantly surprised by what I got out of it , Two mics to th preamp , direct from my guitar , so three channels .The guitar was ALSO going thru a Mono version of these same preamps . Mic left , Guitar Center , Mic Right . I was in audio heaven , Fat studio sound on a Budget . And very Clean .I am also buggin for a Tivoli Model One Radio , if anyone wants to do some trading , ( The Japanese Version , the frequencies are different , the FM band is WAY narrower only goes up to a little over 90 mhz , the US version goes to 108 . Edited May 28, 2009 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
Strungup Posted June 4, 2009 Author Report Share Posted June 4, 2009 (edited) 768 views , ........ not one nibble .Ok I will break it down this way Here is my cost on these 1300 yen per channel for the preamp circuit . 2 channels = 2600 yen circuit parts alone another 1350 yen for the Case , we are up to 3950 yen Then the XLR connectors are 1250 yen each = 2500 yen 6450 yen so far Output Jack is no cheapo garbage . 780 yen Power switch = 800 yen Battery popout 1850 yen ( From Yamaha Guitar distribution ) 9880 yen Parts alone = then My time and tool work and I am only asking 150 and shipping .............?!?! Interesting ........... Edited June 4, 2009 by Guitarfxr Quote Link to comment Share on other sites More sharing options...
