bluecrab Posted May 22, 2009 Report Share Posted May 22, 2009 (edited) Does anyone know if the Sony MZD-N430PS portable MD recorder has Type S?It is this one:http://esupport.sony.com/US/perl/model-hom...430PS&LOC=3Sony's specs don't include this important information :-( Edited May 22, 2009 by bluecrab Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 22, 2009 Report Share Posted May 22, 2009 Yes it does. ChrisG bought one, and either he got that info off the unit, or I found it on the web before that.Basically all portables since Type-S was invented, have it. Quote Link to comment Share on other sites More sharing options...
bluecrab Posted May 22, 2009 Author Report Share Posted May 22, 2009 Yes it does. ChrisG bought one, and either he got that info off the unit, or I found it on the web before that.Basically all portables since Type-S was invented, have it.Thanks. Just one more question then...when was Type S invented? I have never been able to determine what ATRAC, exactly, is on my MZ-R500. (As an aside, the 1xAA play times noted for this unit seem a little less than I am actually getting.) Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 22, 2009 Report Share Posted May 22, 2009 Thanks. Just one more question then...when was Type S invented? I have never been able to determine what ATRAC, exactly, is on my MZ-R500. (As an aside, the 1xAA play times noted for this unit seem a little less than I am actually getting.)If you look at the list on browser (list is in order) the N10 looks like the first to have it. Quote Link to comment Share on other sites More sharing options...
