fukuda Posted May 27, 2009 Report Share Posted May 27, 2009 (edited) A Hi-MD disc is not recognized by SonicStage 4.3. After a while trying to read/mount it, an error message appears and clicking OK closes SonicStage. This disc has been used one time.The same minidisc put in a RH1 or RH910 is not recognized an the apparatus shows a message indicating "Audio File Error" and then "Access Error".When I Try to record something with a mike the recording seems to begin and a few seconds after a message "Rec Error" appears.The recorders work fine with other MDs.Sometimes the screen shows a blinking message "Writing System Files" and after a while the recorder shuts off.I cannot initilize this disc as it is not recognized by SonicStage.Is it good for the bin... or has anyone an idea to "save" it ?Many thanks in advance for your help. Edited May 27, 2009 by fukuda Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 27, 2009 Report Share Posted May 27, 2009 Question: have you tried another 1GB disk? It may be that the unit is not recognising it as HiMD somehow (not sure how, but there is a sensor or microswitch that looks at holes in the bottom of the disk to see what sort of disk it is - there is one hole that is quite different between HiMD and Std 80m MD, presumably this one). Quote Link to comment Share on other sites More sharing options...
kino170878 Posted May 27, 2009 Report Share Posted May 27, 2009 Sometimes if you do an editing operation while the MD unit is connecting to the PC then I think Sonicstage can corrupt the disc. But I think you should still be able to erase it....strange Quote Link to comment Share on other sites More sharing options...
fukuda Posted May 28, 2009 Author Report Share Posted May 28, 2009 Question: have you tried another 1GB disk? It may be that the unit is not recognising it as HiMD somehow (not sure how, but there is a sensor or microswitch that looks at holes in the bottom of the disk to see what sort of disk it is - there is one hole that is quite different between HiMD and Std 80m MD, presumably this one).Other discs are perfectly read in both recorders. This disc is a quite brand new one. Blue Hi-MD by Sony.Sometimes if you do an editing operation while the MD unit is connecting to the PC then I think Sonicstage can corrupt the disc. But I think you should still be able to erase it....strangeMaybe it has been corrupted by manipulating when trying to have it working. I don't know what could have happened. Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 28, 2009 Report Share Posted May 28, 2009 Other discs are perfectly read in both recorders. This disc is a quite brand new one. Blue Hi-MD by Sony.But can you write to the other disks?If one recorder isn't writing (specifically to 1GB disks) then you should be able to reformat the failing one in another recorder that's not bust. Quote Link to comment Share on other sites More sharing options...
