Pruitts Posted July 1, 2009 Report Share Posted July 1, 2009 Is there a way to set tracks to editable again? I have a funeral service that was recorded on mini-disc with an RH-1. One track doesn't transfer with SonicStage, and gives an error that it is unreadable. It is the pastor's message, and the family would really like to have a CD made of the service. The track is 8:01, and can be played up to 7:50 before it skips to the next track. If I could set a track mark at 7:50 I would have most of the message, but because we've tried to transfer it with Sonic Stage, editing is blocked. Any help would be appreciated.Steve Quote Link to comment Share on other sites More sharing options...
sfbp Posted July 1, 2009 Report Share Posted July 1, 2009 I would NOT try writing to the the disk. Either play it back connected to the computer (if it's HiMD format) through the USB and arrange to record the sound stream (we can help you with that), OR play it back with the headphone out using a 3.5mm (1/8") stereo jack to the line input on your computer's sound card (you will have to do it this way if the recording is SP,LP2 or LP4).good luck and welcome to MDCF Quote Link to comment Share on other sites More sharing options...
