drmw1 Posted July 9, 2009 Report Share Posted July 9, 2009 I recently started to use this machine again and having placed a disc inside it shows the above error. I have tried several minidiscs that work on my main hi-fi so i know they work okay. I have tried a compressed air canister to blow out any dust but no joy. Any help is much appreciated. Quote Link to comment Share on other sites More sharing options...
bluecrab Posted July 9, 2009 Report Share Posted July 9, 2009 I recently started to use this machine again and having placed a disc inside it shows the above error. I have tried several minidiscs that work on my main hi-fi so i know they work okay. I have tried a compressed air canister to blow out any dust but no joy. Any help is much appreciated.Infamous and common bug for this machine. Mine died a similar death. There is at least one report of success in fixing it, if it's UTOC Error:http://forums.minidisc.org/lofiversion/index.php/t19479.htmlIf you don't feel like doing that much, just hit Ebay, but avoid this model. Quote Link to comment Share on other sites More sharing options...
drmw1 Posted July 12, 2009 Author Report Share Posted July 12, 2009 Many thanks for your reply this fault occurred only after i changed the battery and now wont even work when plugged in with power supply ah well never mind! Quote Link to comment Share on other sites More sharing options...
sfbp Posted July 12, 2009 Report Share Posted July 12, 2009 Many thanks for your reply this fault occurred only after i changed the battery and now wont even work when plugged in with power supply ah well never mind!That indeed raises a totally different question. Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger. The manual says you can do that. Quote Link to comment Share on other sites More sharing options...
