NetMD MZ-N910 Software Driver
itconstruct
Welcome to MDCF!
As far as I know, the situation is: Windows 64 - no chance. Windows 32 should work on either. You can find a version of SonicStage here with everything perfect.
Let us know if you need more help. If you have W64, you're going to have to run a W32 virtual machine. Whether you can do this by simply checking a box to tell it W32 compatible, or have to start a separate VirtualPC session, I am not sure, since I haven't actually run 64-bit anything. There are folks here who have.
Also you should tell us what you are trying to do, especially since this is your first post. We might need a bit more information to be able to help you out of wherever you are stuck.
