StephenS Posted August 8, 2009 Report Share Posted August 8, 2009 I have been using Sonic Stage 4.2 and MD Simple Burner on a Windows XP desktop, with no trouble. I have now got a Vista laptop and I have downloaded SonicStage 4.3. I tried to install Simple Burner, but was unable to do so, as Vista does not appear to be supported. Is this right, and have you any suggestions?Steve Quote Link to comment Share on other sites More sharing options...
culp4684 Posted August 8, 2009 Report Share Posted August 8, 2009 StephenS said: I have been using Sonic Stage 4.2 and MD Simple Burner on a Windows XP desktop, with no trouble. I have now got a Vista laptop and I have downloaded SonicStage 4.3. I tried to install Simple Burner, but was unable to do so, as Vista does not appear to be supported. Is this right, and have you any suggestions?SteveYou are correct. Vista does not support SB. Not sure exactly why. I always thought each M$ version was always backwards compatible with previous ones... Quote Link to comment Share on other sites More sharing options...
Avrin Posted August 8, 2009 Report Share Posted August 8, 2009 The only way to use Simple Burner on a Vista PC is to use a virtual machine with USB support and Windows XP installed.And no, Vista is in no way backwards-compatible. Most applications need to be upgraded to work with it. And some (including Simple Burner) don't have such upgrades available. Quote Link to comment Share on other sites More sharing options...
StephenS Posted August 9, 2009 Author Report Share Posted August 9, 2009 Thanks for the information. I was afraid that might be the case, a shame as I always found Simple Burner nice and easy.Steve Quote Link to comment Share on other sites More sharing options...
Avrin Posted August 9, 2009 Report Share Posted August 9, 2009 Yes, it's a nice little program. And even nicer, if we remember that NetMD tracks transferred to a disc via Simple Burner, may be uploaded back using the RH1. SonicStage tracks are not uploadable. Quote Link to comment Share on other sites More sharing options...
