RED SHIFT1 Posted September 8, 2009 Report Share Posted September 8, 2009 I have the Sonic Stage 4.3 Digital Music Manager (or something like that) on my PC. I have been using for some time now to keep up with my music; I generally import cds or files into it. Just today I noticed that the amount of memory availible for storage has gotten down to below 10 gigs. I am far from finished...is there anyway to increase the amount of memory? I do have an excternal hard drive if that means anything. Attached is a screenshot of the memory thing...my library.doc Quote Link to comment Share on other sites More sharing options...
Richard Posted September 8, 2009 Report Share Posted September 8, 2009 You can use an external drive with SS - in fact this is what I use myself. You should be able to move the files from within the options; Tools => Options => Location to save imported files.. To quote the help If you change the location to save files, a dialog box appears prompting you to confirm whether to move files in the previous folder to the changed folder. Clicking "Yes" moves the files to the changed folder. I think when I orignally moved mine to an external drive I just copied everything across via explorer and re-imported but I didn't have a very large library then and I had to re-add some of the cover art.. Have a search using Sonic Stage +external drive, there are few topics on the forum already dicussing this. * Moved to Software section Quote Link to comment Share on other sites More sharing options...
