Omgjbox.exe error
Dre Dre
ok party people, i have a NW HD5. i also have sonic stage 3.4 running, and when i say running i use that word very loosely. everytime i try to import files of any desciption the program either 1) shuts down immediatly with no error messages or 2) shuts down and spits out an error message about omgjbox.exe. i have tried getting in touch with sony but they are about as useful as a bucket of s**t. SOMEONE HELP ME!!!
Here Are my Specs:
PC
- Pentium D CPU 3ghz (Dual Core)
- 1 gig ram
- XP Home Edition SP2
- 7800 GT 256 MB
- USB 2.0 + USB 4 port hub
- 250 gig HD
Software
- Sonicstage 3.4 (was running 2.1 but with the same problem, hence getting the update)
MP3 Player
- Sony NW HD5
Apps running at time of Crash
- Trend Micro PC-cillin Internet Security 2006
- MSN Messenger v7.5
- AVG Free Edition
- Nostromo Loadout Manager
- Intellitype Pro
- Intellipoint Pro
Edited by Dre Dre
I have uninstalled it. deleted the registry entries, and re-installed an older version (3.1) and still get the same problem! DAMN YOU TO THE DEPTHS OF HELL OMGJBOX.EXE!
Some questions for you:
- Is this problem only happening when you are trying to import?
- Can you use SS and is it just when importing that you get errors?
- Will tracks play?
- Can you acess your DAP? Can you play your files from your DAP?
- Probably won't matter, but update your computer with Windows Update. Could work out.
Have you done a google search for 'OMGJBOX.exe import' error ?
Edited by JSP62
  • 2 months later...
Hey, pal!
I had the same problem - upon importing folders SS crashed after saying that omgjbox has done smth wrong. What I did - I just installed SP2 for my XP Home edition. And after that - everything runs smoothly.
Try and maybe it'l help you.
Cheers
Hi,
From Sony's support site:
When I run SonicStage, the following error message appears (Microsoft Windows XP): Omgjbox.exe has encountered a problem and needs to close.
Please check the following:
Make sure that you are using a computer with an account that has the administrator rights.
Make sure that you have downloaded the latest SonicStage version available from the download section of our website.
Make sure that you have updated your computer and your operating system with the latest updates. Please contact the manufacturer of your computer / operating system.
Make sure that your computer is free from spyware: for more information, please visit the Microsoft security website.
Disable DEP settings:
Click Start, right click My Computer, and then click Properties.
On the Advanced tab, click Settings under Performance.
On the Data Execution Prevention tab, select Turn on DEP for all programs and services except those I select, and click Add.
In the Open box, browse to the C:\Windows folder, double click Explorer, click OK, and then click OK.
Don´t ask me why, sure it has to do with some awful programming, but it worked for me
  • 3 months later...
I have an ATRAC NW-E003
I installed SonicStage 3.4 wich came with the device
and I'm getting problems with Omgjbox.exe when I try to transfert files
it makes the application crashes
I have windows XP sp2
AMD athlon 64 2Ghz
1Go Ram
USB2.0 port
my windows intallation is feshly installed...
I installed all the updates on microsoft web site...
all my drivers are up to date...
I've enabled DEP for windows explorer...
..and it still crash
I'v tried to install SS cp 4.0 and I got the same problem...
how come is it so difficult to install a program that should simply write files on a usb memory !?!
I've tried also on Intel pentium4 computer and it doesn't work
is there a problem with the usb device??
This thing gets really funny)) Sorry pal but that's the truth. No one knows how to cope with this error. I believe neither does Sony. But Im pretty shure that this is just SS software and it has nothing to do with ur player. You can try what was already said about DEP settings or SP 2. Maybe this can help. I guess the best thing you can do is write a letter to the support team.
I also have this problem. But it occurs only when I'm importing many tracks (something like 3-5 albums). When this number is less - everything goes smoothly. Try.. may help.
Cheers
