Sony Insider Forums
Sennheiser Cx300 (Pictorial+ Review)
Guest Stuge
Guest Stuge
Short Review on Sennheiser CX300 :clover:
Not sure what to write but i still have to write something b`coz i promised everybody..I have tested these phones with my MZ-DH10P ,NW-HD5,NW-E505 & D-NE900 in Different bitrates from Atrac192kpbs -352kpbs &,Mp3 192kpbs-320kpbs & with Audio cd`s as well .
--Pros(Good Points )
1.)They are very Comfortable (Three Diffrent Ear fit rings or tips are provided )
(i)Small,(ii) Medium,(iii)Large
2.)They provided good Isolation from outside sound (acc to me around 10-20db)
3.)Sound is balanced but not very bassy as i was expecting .
4.)Lows are quite clear.It also depends on how you set the equaliser settings .
5.).Cable quality looks Good .
6.)Good for listening Jazz(I basically listened to Norah Jones Songs ;) )
Cons .
1.) No case is provided to keep phones .
2.) Not good for listening Disco or even Pop or Rock .
3.) For $60-70 they are not very immpresive .
4.) .Length of the cord is ok ,1m.
5.) .Sound is very Tiny even at high Volumes
6.) Shlight Hiss is listenable with CX300 which quite irritating
ON 1 to 10 scale, I will only give 5 points .
Those who like less Bass will like these phones
Havn't posted in a while...
Still toying with the idea of buying a pair of these. The pictorial and review is very much appreciated, ny sound is tiny even at hogh volujmes do you mean tinny? or just quiet (i find this to be the case with my EX81)?
Still don't think i'll be parting with my cash anytime soon for a pair of these. (partly because i have very little atm)
Guest Stuge
Yeah ,Even if you compare these with E805 or E808..You can listen these at volume 13 but with Cx300 i neeed to rasie the vol to 20 ..
I you really want to buy these then rather go for Ex90 .
Stuge is it possible that you may have a defective pair of CX300 ?
I just rec'd mine on Friday from Wicked Digital.
Straight out of the box they are noticably louder than EX51 & NX1 by 3-5 on the volume setting for A1000 or N407. The sound has is clearer with more bass definition & pressance than the Sonys. The Sony's bass is "boomier" compared to their more neutral sound. This is with a medium size ear pad.
It will be interesting to see how they age.
Guest Stuge
I don`t think soo ..Now they do sound louder then before but i still don`t think they are good for Pop/Disco type music.
Stuge, I think that this time you found the sony hdd players hiss :)
Remember that previous thread.
Check when that hiss is listenable, with the device playing and volume in the minimum. Then try to pause the device, and you'll shall hear no hiss. ;)
When I was comparing the CX300 with EX51. I had to switch the small earpad on the EX51 to medium and it improved the bass sound in particular and the isolation. It is not quite as comfortable but more secure.
Nevertheless the CX300 is still superior.
