Christopher Posted June 30, 2010 Report Share Posted June 30, 2010 Hello everyone, I am working with my host and Invision to fix some of the current problems here, including the "My Settings" issue. I will also be fixing the cosmetic appearance of the forum in due time to at least have it reflect it is the Sony Insider Forum..the default skin is obviously not what it used to be after we did a recent upgrade. My sincere apologies for taking so long to attend to this issue, it was an extremely poor move on my part and quite disrespectful to the fine folks who have spent time helping others here. Link to comment Share on other sites More sharing options...
Christopher Posted September 29, 2010 Author Report Share Posted September 29, 2010 Fixed the my settings issue, thanks to sfbp. Board fixes have taken longer than usual because my host is taking forever with memory upgrades. I am so sorry. Link to comment Share on other sites More sharing options...
Christopher Posted October 18, 2010 Author Report Share Posted October 18, 2010 Fixed the My Settings issue with the default skin..I swear I had fixed that before. But you should now be able to access "My Settings" on the drop down menu on the upper right. Link to comment Share on other sites More sharing options...
sfbp Posted October 18, 2010 Report Share Posted October 18, 2010 It may be that every time a skin is changed the fix you made goes away..... Stephen (ie you may want to try fixing the template someplace) Link to comment Share on other sites More sharing options...
