single track play differences
tahih
Hi, I just got an mz-m200 to replace my mz-rh10. On the rh10's remote I can press play/mode to select a single track to play and then the unit will stop afterwards (a little number one will appear on the remote's lcd) I can't find a way to do this on the mz-m200. It seems it only offers repeat play. Anyone know a way to do single track play then stop with the mz-m200? Thanks.
Hmmm - this function does not appear to be supported. The best you can do is to bookmark the track(s) you want, and then play bookmarked tracks only by cycling through the play modes (this should work for what you want to do, in fact).
See page 43 of the manual
Good luck!
