Finally, the much anticipated firmware update that enables AAC support for the NW-A1000/1200/3000 is now available for download. The firmware update is of version 3.00 and amount to approximately:
Playing back with AAC format* is available without any format change. Therefore, AAC format files in SonicStage CP can be transferred without converting them to ATRAC format.
*Note:
i. Sampling frequency: 11.025/12/16/22.05/24/32/44.1/48kHz
ii. Supported bit rates: 16 - 320 kbps, VBR (Variable Bit Rate).
iii. Copyright protected AAC files cannot be played back. In addition, it is not guaranteed that all of AAC files can be played back even if the above conditions are met.
The Artist Link Shuffle mode is added to the Intelligent Shuffle.
The clock display and calendar display functions are added. If CONNECT Player or SonicStage CP is used, the unit clock synchronizes to the computer when the Network Walkman is connected to the software.
The screen saver is selectable.
Group +/- can be operated using the compatible stick controller (RM-MC35ELK). Playback can be adjusted to the beginning of the first track in the previous or next group from the current group, regardless of the starting position or the playmode. It is also possible to move to the first track of the group in Playlist, Bookmark, Trash Bin and Favorite 100.
IMPROVEMENTS
The sorting order is based on the album track number rather than alphabetical order when Artist ALL is selected from the Artist tree of the List search.
The animation design which appears while the HDD is accessed is changed.
The resume track information reset is prohibited with the recharge operation.
<HR noShade SIZE=1>
INSTALLATION PROCEDURE
Please follow the procedure below to check the firmware version installed on your NW-A1000/1200/3000 WALKMAN:
1. Press and hold the BACK button until the HOME menu appears.
2. Press settings , (up) / (down) / (left) / (right) to select (config) and then press (play).
3. Press (up) / (down) to (Unit information) and then press (play).
4. Confirm the firmware version
--> Create the following folder on the C:\ drive of your computer: : FWUP
--> Read the disclaimer at the bottom of the page and click I accept to download the program
--> Follow the instructions and save the program to C:\FWUP
--> Check that the downloaded file corresponding to your device (1) NW-A1000 - 6,037KB (2) NW-A1200 - 6,037KB and (3) NW-A3000 - 6,038KB. If not, delete the file and repeat the download steps.
<HR noShade SIZE=1>
UPGRADE PROCEDURE
Once the download is finished, please follow the steps below to upgrade the program.
Before updating the firmware, return all music files and data files of the unit to the computer. After firmware is updated, it may not be possible to use the music files and data files on the unit. Sony is not responsible for music files and data files that cannot be saved on your computer due to the updating.
1. Connect the unit to the PC.
2. Click Start button on the task bar and click Run - The Run dialog box will be open.
3. Browse to C:\FWUP\NW-Axx00_V3_00.exe in the Open text box and click OK. The program will be started.
4. Follow the following screenshots:
*If “Charge the device before performing the software update.” is indicated, this means that the battery needs to be recharged. Then, update the firmware again.
5. Accept the License Agreement and click Next
6. Connect the NW-A1000/1200/3000 to your computer and click OK.
7. Close all the programs and click OK.
8. Click OK to start the update process.
9. Safely remove the USB device from the computer and Click OK
10. After a few seconds the firmware will update automatically on the device. Once finished, it will restart. Click OK
<HR noShade SIZE=1>
AFTER UPGRADE
Please confirm the version when the upgrade program is installed successfully with the above steps. The upgrade program installation is succeeded when “3.00” is shown on the screen.
Ishiyoshi
NW-A1000/1200/3000 Firmware Update 3.00
- NW-A1000 - 6,037KB
- NW-A1200 - 6,037KB
- NW-A3000 - 6,038KB
DOWNLOAD Links: Japan/Asia-Pacific: NW-A3000 | NW-A1200 | NW-A1000NEW FEATURES ENABLED:
- Playing back with AAC format* is available without any format change. Therefore, AAC format files in SonicStage CP can be transferred without converting them to ATRAC format.
- The Artist Link Shuffle mode is added to the Intelligent Shuffle.
- The clock display and calendar display functions are added. If CONNECT Player or SonicStage CP is used, the unit clock synchronizes to the computer when the Network Walkman is connected to the software.
- The screen saver is selectable.
- Group +/- can be operated using the compatible stick controller (RM-MC35ELK). Playback can be adjusted to the beginning of the first track in the previous or next group from the current group, regardless of the starting position or the playmode. It is also possible to move to the first track of the group in Playlist, Bookmark, Trash Bin and Favorite 100.
IMPROVEMENTS*Note:
- The sorting order is based on the album track number rather than alphabetical order when Artist ALL is selected from the Artist tree of the List search.
- The animation design which appears while the HDD is accessed is changed.
- The resume track information reset is prohibited with the recharge operation.
<HR noShade SIZE=1>INSTALLATION PROCEDURE
<HR noShade SIZE=1>
UPGRADE PROCEDURE
<HR noShade SIZE=1>
AFTER UPGRADE
<HR noShade SIZE=1>
25 answers to this question
