Bring back 3.4!
hp1975
I mean it, I thought 3.4 was spot on apart from the intelligent features not working. Now all I get i sproblems with 4.0
It keeps deleting the database
Huge chunks of albums have just vanished
when you connect it it just hangs amd then deletes the entire database...again....it sux
Please can someone point me in the direction of 3.4, I dont really want to go back to a system restore point unless I have to.
cheers
HP
Thanks guys.
Stuge, you're right, I think what happens is that when it is updating the database (i guess with all the intelligent features) it hangs and then if you just leave it for a while it finally produces an error, and then the database is corrupted on the device, it shows no songs what soever. Very strange.
Anwyay I think I'm gonna stick with 3.4 until an update for 4.0 is released.
Even when the program transfers files over and you get an error and the program crashes and corrupt database or no database is found on the devise, all you do is reconnect the player and the songs will reupdate, but won't have to transfer again.
this happened a few times for me with early versions of connect player, the first one mostly, not so much the later versions, and with the latest 2 updates, no errors what so ever.
I guess this is why I prefer Connect Player, much simpler, faster and easier to use. anyways, whatever floats your boat.
