probleme S/PDIF MZ-RH1
hello.
I am a French living in France.
I can speak English, so excuse me for the foul.
I have the MZ-RH1.
when I make a pause / recording analog I can set the recording level.
but once I make the same manipulation in digital (S / PDIF) I can not adjust the level.
On it are the manual explain that may have set the logging level as in analog and digital.
thank you in advance for your help.
akiomorita.
Actually I think this one is quite simple. Do you have Synch Rec selected? (It's a menu item, NOT a switch, although on some units this Synch Rec is a hardware switch).
See page 53 in both English and French manual(s). It's the last comment before "Menu de Lecture" or "Menu for Playback".
Welcome to the forums.
Stephen
Hello Stephen.
Yes you are right it should turn off sync rec.
I who have walked the man page I found was listed on page 53 :sad: .
I like to thank you so much for the help you've given me.
I hope you can help one day may be.
Sony insider has also thank you.
I must confess that I would very much alone with my little world of Minidisc forums are nonexistent!.
I fortunately have rejoind Sony Insider.
