Sony JBS-940 clipping start of digital recordings
herky10
Digital connections take some setup time. Does this happen when you put it into record-pause mode with the digital signal in connected?**** To avoid losing the beginning of recordings, you can start them by pressing the (circular) AMS knob. This will dump the 6-second buffer to MD. At that point fractions of a second become irrelevant no matter how they are caused.
Hope this helps.
**** if you have it busy recording but don't turn the digital signal on until the last moment, then this will never work. You will always lose the digital setup time, just as you describe.
