Juzanotherguy Posted November 13, 2011 Report Share Posted November 13, 2011 Dear all bros, I need help on my MZ-N505 Net MD as i found it during cleaning of my room but it can't play and came out with NV ERR. I tired to search for help but can't find the solution. So is there a way to clear this error. Hope to see your reply soon. Thanks Regard Christopher Quote Link to comment Share on other sites More sharing options...
sfbp Posted November 13, 2011 Report Share Posted November 13, 2011 You'll have to go through aligning the drive. If you are experienced enough to get into service mode, you can try fixing the byte at 024 (to FF). Try reading this thread: However, it's possible you have to reload the NV data. There's an application you should use - called NV Patchwriter. However I don't have it for N505. Quote Link to comment Share on other sites More sharing options...
Juzanotherguy Posted January 27, 2016 Author Report Share Posted January 27, 2016 after so many years i still can't figuring out this problem have gone through all these but still unable to solve my problem. Anyone can help me with this? Hope this can be solve. Thanks Quote Link to comment Share on other sites More sharing options...
Azureal Posted January 27, 2016 Report Share Posted January 27, 2016 Welcome back! :-) Quote Link to comment Share on other sites More sharing options...
Juzanotherguy Posted January 29, 2016 Author Report Share Posted January 29, 2016 Thanks, but still no help. Anyone can help me with this? Quote Link to comment Share on other sites More sharing options...
