Sony MDX-100 Fascia Surround Trim
condor655
Try here:
http://www.partstore...ony/MDX100.aspx
I just special-ordered the sub-panel for an MDX-C5970 from them.
But.... I think the trim required will be specific to the car?
So it's more like a "Sony" fascia kit for brand X of automobile. Unless I misunderstood OP. However most Sony units (but not all) are essentially what is called ISO (or single-DIN) which is a standard size, and to get your MDX-100 you have to get the right piece of plastic that fits the car you own.
For example to get the MDX--CA790X into my wife's Toyota, I ordered this:
http://www.installer.com/item/display_item.php?it=TA2045B
The other thing needed (maybe I am preaching to the choir already) is a so-called wiring harness, for example:
http://www.installer.com/item/display_item.php?it=70-1761.
However if the unit already has plugs in it that end in wires, and there are bare wires in the car, you won't need that. I had to buy TWO wiring harnesses - one for the Toyota end, one for the Sony end, and then join the wires correctly between them. This avoided cutting up the harness on the factory-installed radio in case I want to put it back before reselling the car.
Sorry if I am completely off base here. Maybe you and OP know something specific that I do not.
Stephen
