casiokorg Posted January 19, 2013 Report Share Posted January 19, 2013 Hey everyone! I was given a Rh10. it works great and I'm enjoying it a lot, although whenever i try to go into the recording settings, it just tells me I cannot set any of them. i've tried to edit other areas, thinking it would unlock those features, but nothing works. am I doing something wrong? also, can i transfer songs via USB to a regular MD, or do i need to shell out $20 for a single HI-MD? thanks! Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted January 19, 2013 Report Share Posted January 19, 2013 i cannot fix your settings access but yes you can use any standard MD as a Hi-MD disc. Just ask the RH10 or SonicStage to use it that way. Quote Link to comment Share on other sites More sharing options...
casiokorg Posted January 19, 2013 Author Report Share Posted January 19, 2013 Everything works but the REC Mode, REC Level, and the Time Mark. Everything else I can edit in the menu. there has to be a reason for this. it doesnt seem tobe a mechanical issue at all. Someone must know why it's doing this. Thanks Quote Link to comment Share on other sites More sharing options...
casiokorg Posted January 19, 2013 Author Report Share Posted January 19, 2013 OH...I found out the reason: "you can record only in HI-MD mode on this recorder. If you want to record in MD mode, connect recorder to a computer and record or transfer audio data using the supplied software" Quote Link to comment Share on other sites More sharing options...
PhilippeC Posted January 20, 2013 Report Share Posted January 20, 2013 OH...I found out the reason: "you can record only in HI-MD mode on this recorder. If you want to record in MD mode, connect recorder to a computer and record or transfer audio data using the supplied software" I was not aware of that limit on the RH10. I have a NH700, a NH900 and a RH1. I don't record something with my RH700 yet but my NH900 and my RH1 both allready recorded in real time with line in dozens of MDs in SP and LP2 modes. Quote Link to comment Share on other sites More sharing options...
