Portable Winamp
f1rick
I came across portable winamp
*** link removed as it has expired ***
Copied it over to the HD5, added in the ml_sony into the plugin folder and now I can run winamp directly from the walkman :D . With the drag and drop the plugin supports it makes this a direct replacement for mp3 file manager B) . Only takes up 4.5mb too.
Edited by f1rick
  • 3 weeks later...
  • 7 months later...
  • 5 weeks later...
  • 4 weeks later...
