Victor XM-PX33 Disassembly Help
Boomchild
So I have this Victor XM-PX33 which seems to have a loose headphone jack. When I looked to taking the unit apart, I can only locate one screw on the outside of the case which does not seem to allow me to get the unit's cover off.  I was wondering if anyone here has worked on these and can shed some light on how to disassemble the unit. Any help would be greatly appreciated. Thanks.
A diagram and instructions on how to at least start to disassemble this unit can be found at the link below.  Hopefully you will be able to figure out the rest of the process.  It looks like the rear casing will have to be removed after you have taken apart the front of the unit.  I hope this helps and good luck:)
http://www.manualscenter.com/manuals/jvc/xmpx33wtbu-service-manual.html#.VCEo-mex7IU
