choudy Posted April 12, 2015 Report Share Posted April 12, 2015 hi - do you know if it is possible to use the line out with a remote attached. Each time i try it reverts back t headphone out. is there anyway to fix this? Quote Link to comment Share on other sites More sharing options...
sfbp Posted April 12, 2015 Report Share Posted April 12, 2015 No. But you could simply measure the signal level from line out and duplicate that with the remote. The passage through the remote should be clean. For analog signals I'm pretty sure it's 30. For digital it may be (according to a former regular contributor) 23. But your problem is analog. Quote Link to comment Share on other sites More sharing options...
choudy Posted April 12, 2015 Author Report Share Posted April 12, 2015 I see - thanks for the reply Quote Link to comment Share on other sites More sharing options...
