pmcc Posted August 5, 2006 Report Share Posted August 5, 2006 i wish to rename OMGAUDIO backup To OMGAUDIO so i can get my music back however an OMGAUDIO folder already exists.do i replace this folderplease reply asaphd5h model by the wayim trying to do this via windows explorer. do i need to run gym again and do it via that programwhen you reply can you give me step by step instructions Quote Link to comment Share on other sites More sharing options...
JSP62 Posted August 9, 2006 Report Share Posted August 9, 2006 rename the current OMGAUDIO to some other name (i.e. OMGAUDIO_TEMP) then rename the OMGAUDIO backup one you have to 'OMGAUDIO'. If you music all returns and everything is okay, delete the original OMGAUDIO.If you still have errors, you have the back up original folder to work with again.________________________________________You would only need to run GYM again if you had some sort of error when you previously ran it._________________________________________There is a step-by-step instructions for GYM that should have been included when you downloaded. If not, go to the GYM website for directions. Also reference this forum for specifics if you run into trouble.Good luck! Quote Link to comment Share on other sites More sharing options...
