converting mp3 to AT3
PatrickLux
I think you need the (Sony) Windows-based DLL's regardless, so unless you actually run Windows (Parallels) on it, there is no way legitimately from Sony.
The Mac has/had support for ATRAC3+, but not sure what happens to that with newer versions of OSX. But not ATRAC3 and NetMD.
Try VLC. It should work, provided you have a version that's less than about 2 years old. FFmpeg should be fine even older than that (requiring use of hairy command line parameters, actung vorsicht!)
