Problem w/ my 507
mfremon
I went running with mine 2 days ago and accidentally left it on. It ran the battery's completely dry and I comletely recharged it the next day. The problem is when I hit the play button, it doesn't play and turns itself off after about 15 seconds..When I put headphones in it, it scans the "Data Access"....I keep it in a ziplock bag in my pocket so its not rain or sweat that gets in it...Am I S.O.L.?....Am I going to have to buy one of the cool new NW-E one's now as I had no problems with mine at all....
Thanks for any help
4 answers to this question
Tried both ideas and it didn't work....Got in contact with Sony and was told to disconnect/connect the battery and then it should probably work...Got it all apart except for disconnecting the power source and therein lies the problem...Has anyone pulled theirs apart and how were you able to disconnect the power source w/o causing more damage?
I will not advise you to disconnect the battery plug yourself but still you can look into E507 service manual --> http://www.atraclife.com/downloads/download.php?file=98
