lexm Posted October 7, 2017 Report Share Posted October 7, 2017 Hi, I encountered a problem that did I not not found mentioned earlier in this forum: I successfully executed the sequence of installing the driver under windows 10: saw the yellow exclamation mark, switched off the signing check, successfully installed the driver. after this was able to use Sonic Stage 4.3 to copy tracks to and from the drive. both in MD mode and in HI-MD mode. However, the next day, this only worked in MD mode. if an MD disc was inserted: all fine. then press stop button, wait for message "OK to eject disk" , switched for a HI MD disk while device manager window was still open. after the disc was recognized in the player, the device manager window text switched from "Device is working properly" to "Device is not recognized" . in the Eventlog the message "Device not migrated, cannot migrate Device" switching back to an MD disk and all is fine again. tried this also on another PC with win 7 64 professional: same result. what did I do wrong? why did it work the first day only? what can i do to make HI MD working again? thanks for helping out Quote Link to comment Share on other sites More sharing options...
sfbp Posted October 8, 2017 Report Share Posted October 8, 2017 Windows Update. Turn it off. Reinstall Sonic Stage. Quote Link to comment Share on other sites More sharing options...
lexm Posted November 24, 2017 Author Report Share Posted November 24, 2017 Thanks for helping out. Solved the issue by installing the software in windows xp in vmware. Quote Link to comment Share on other sites More sharing options...
