MZ-RH1 Recording Problem (Hardware) ...solved
rymannphilippe
Hello all
Here are a problem i found on a recently bought minidisc from ebay with no working recording.
I really didn't know what is the problem. I only found interesting in recording mode the tray was not locked.
So i open the minidisc to the all its single parts and found the issue.
-->-->--> The problem was in the gearbox for the lock mechanism (the lock mechanism also lower the upper part of the read/write head).
After a little autopsie and with some super glue i managed to fix the gearbox.
What i beauty it work like new again.
I hope you can enjoy the pictures and it helps others with the same problem.
PLEASE WATCH THE ONGOING PROBLEM AFTER THIS MECHANICAL PROBLEM I SOLVED:
http://forums.sonyinsider.com/topic/29963-mz-rh1-new-recording-problem-hardware-unsolved/
