Joel n Posted May 15, 2019 Report Share Posted May 15, 2019 Hey everyone! Picked up an mz-n10 awhiles back on ebay but unfortunately it didnt come with a charging cradle. Now the internal battery has completely died and wont switch on, does anyone know anywhere i might find a cradle ?? Getting no love on Ebay so far.. Tha ks for any help! Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 15, 2019 Report Share Posted May 15, 2019 Forget that.... you need to read on here how to replace the battery. See some posts by Jimma, I think. Quote Link to comment Share on other sites More sharing options...
alexa2005 Posted May 22, 2019 Report Share Posted May 22, 2019 Hello, You can charge it if : 1. Look in service manual, last pin of the connector is charging pin, +6Volt, ground can be taken from any metallic part of the body. 2. You can buy an usb cable and use the connector in the same way line up description, to charge the battery. Charging will start from 5,5Volt and current is about 250mAmps. Battery of the same dimension can be found on chinesee sites... Dimensions are 35x20x60 mm. Code for Li-Po battery is the same: 352060. Quote Link to comment Share on other sites More sharing options...
