Connecting House Subwoofers
xale
Hi :)
I bought a caravan with a Sony MEX-N4150BT in it, connected to some outdoor house speakers. Not the latest and greatest I know, but it's what I've got.
I have bought some Sony subwoofers - they are from a home entertainment system. I spliced them into the existing speaker wiring to see if it would work, and it does!
But it's not very 'bassy'. I noticed there are also 4 RCA plugs on the other side which, on reading the manual, seem to be for subs. Can I plug them in here? I've tried, but they don't work.
Not sure if there's s software setting I can't find, or if I need an amp to use the plugs on that side (the others come out of the other side).
Any help and advice would be very much appreciated. Thanks!
4 answers to this question
5 hours ago, xale said:
... or if I need an amp ...
Yes, you do. Sub outs on head units normally meant for either active subwoofers or subs hooked on a power amplifier.
You can also see it in the manual (see as well the other RCA audio outs for additional, externally amplified front/rear speakers):
Sub amps require a lot of power, way more than the regular speakers, and normally there is not enough space in a 1 din head unit  for such an amp. Even if it was feasible, as only a fraction of the buyers install subwoofers, it would be an excess feature, with no value to the vast majority of users.
Something like this do the trick?
This looks like a neat "all-in-one” amp. Good for those who want "bigger sound" than their head unit can provide. I cannot judge though how good its subwoofer circuit is.
If your main speakers are loud enough with the Sony, and the only thing missing is the good bass, I would rather go for a dedicated sub amp, something like this (or eventually, better).
Beware though, that a few 100 Watts on a 12V car circuit means a few dozens of Amperes (!), therefore it would also call for dedicated, thick enough wiring directly from the car's battery (and/or, actually another, dedicated battery, also with some beefy buffer caps, next to the amp).
