bluecrab Posted April 30, 2021 Report Share Posted April 30, 2021 Asking for a friend—an actual SWIM instance ;-) ... Sony MDS-E10 loads MD with write-protect tab closed for track naming - after TOC reading it briefly flashes the track info (or blank disc) and immediately goes to "All Erase?" I've tried it over and over, always the same thing. When pressing eject, it might not respond, or will after 4-5 presses of eject. This happens with various MDs. Any ideas? Quote Link to comment Share on other sites More sharing options...
sfbp Posted April 30, 2021 Report Share Posted April 30, 2021 Jammed microsowitches? Sounds like one for NGY who sadly is no longer with us.... Kevin has worked on the E-11 quite a bit, so I would expect him to chime in here. Quote Link to comment Share on other sites More sharing options...
kgallen Posted April 30, 2021 Report Share Posted April 30, 2021 Chiming. Sounds like a control thing. With the machine off I would give the AMS knob a spin and give the buttons a bit of pressing. By default you probably get to that menu item with two presses of Yes or the AMS button so I’d work those a little to make sure they aren’t stuck. Also crazy as it sounds make sure there is not a Sony remote close by. One of the weirdest problems I ever had was my two racked E12s kept going into play. Turned out the IR remote (which was above/behind the decks) had the play button pressed! Quote Link to comment Share on other sites More sharing options...
bluecrab Posted April 30, 2021 Author Report Share Posted April 30, 2021 Thanks, guys, will pass along! Quote Link to comment Share on other sites More sharing options...
bluecrab Posted May 1, 2021 Author Report Share Posted May 1, 2021 8 hours ago, bluecrab said: Asking for a friend—an actual SWIM instance ;-) ... Sony MDS-E10 loads MD with write-protect tab closed for track naming - after TOC reading it briefly flashes the track info (or blank disc) and immediately goes to "All Erase?" I've tried it over and over, always the same thing. When pressing eject, it might not respond, or will after 4-5 presses of eject. This happens with various MDs. Any ideas? Problem was solved: A keyboard was plugged in and laid off to the side on edge. It was causing this trouble by having a key(s) depressed without being seen. Quote Link to comment Share on other sites More sharing options...
sfbp Posted May 1, 2021 Report Share Posted May 1, 2021 ROFL//// right on, Kevin! Quote Link to comment Share on other sites More sharing options...
kgallen Posted May 1, 2021 Report Share Posted May 1, 2021 :-D the simple solutions are the best! Great news! Quote Link to comment Share on other sites More sharing options...
