Xavier Gonzalez Posted October 5, 2021 Report Share Posted October 5, 2021 Hello I have a BIOS version R1120J7. My PC is a Sony Vaio VGN-FZ240E. creators Phoenix Trusted core of the Bios, I wanted to know how I can activate Virtualization. Quote Link to comment Share on other sites More sharing options...
0 Richard Posted October 5, 2021 Report Share Posted October 5, 2021 I don't know if that model even supports Virtualization, but I would try this link: https://www.sony.com/electronics/support/laptop-pc-vgn-series/vgn-fz240e/articles/00049036 Then review these steps and check if you actually have the option in the BIOS: Press F2 or F3 when restarting: Alternatively: F1 If your VAIO has an ASSIST key, try to press and hold it while you power on the laptop. This also works if your Sony VAIO came with Windows 8 With the computer turned completely off, press and hold the Assist button until the black VAIO screen appears NOTE: The location of the Assist button will be different depending on the computer model. Refer to the operating instructions supplied with the computer for the exact location of the Assist button on your model At the VAIOCare | Rescue Mode screen, press the Down Arrow key until the Start BIOS setup [F2] option is highlighted, and then press the Enter key In the [BIOS Name] Setup Utility screen, press the right-arrow key until the Advanced tab is selected On the Advanced tab, press the down-arrow key until Intel(R) Virtualization Technology is selected and then press the Enter key Use the arrow keys to select Enabled, and then press the Enter key Press the right-arrow key until the Exit tab is selected Press the down-arrow key until Exit Setup is selected and then press the Enter key In the Save screen, verify Yes is selected and then press the Enter key Quote Link to comment Share on other sites More sharing options...
Xavier Gonzalez
1 answer to this question
