Brendan H Posted March 28 Report Share Posted March 28 Having recently dipped my toes back into Minidisc, I was looking for a way to organize and store my discs. There are not a lot of options out there obviously, and I didn't really fancy any of the etsy 3d printed racks. Instead I started scouring through Amazon for something suitable and found a nice little wood storage box. It will hold about 23 minidiscs in their sleeves and they are almost a perfect fit side to side. The lid will not close with the discs in the box, unless you under-stock the box and allow the discs to lean over. If you put in the discs without the sleeves then the lid will close without leaning them over. I just figured I would share in case others find it useful: https://www.amazon.com/dp/B0B6H58VSP?psc=1&smid=A1BMZZZS7AKSSF&ref_=chk_typ_imgToDp Quote Link to comment Share on other sites More sharing options...
BearBoy Posted March 29 Report Share Posted March 29 Looks like a good fit 👍 Quote Link to comment Share on other sites More sharing options...
