Rezső Gubik Posted February 15, 2024 Report Share Posted February 15, 2024 Dear forum members, I've got to my hand a MDS-JE500 MD deck from a first owner in quite good condition. Unfortunately as more I am playing/recording with it there comes randomly an error message while recording: Retry - Retry error. It means, at retry error it skips the current recording to a new separate track. It is really annoying and random. Sometimes a disk is written with max. 2 errors but sometimes with 10+. Following the repair manual I have made a recording test and the focus bias test, here the result was below the limitation: focus errors were below 20, namely 0-5 error/session. The heads are clean and dust free. The symptoms are present with used and new disk either. Any proposals or tips? Thank you! Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 15, 2024 Report Share Posted February 15, 2024 Not sure if this helps https://minidisc.org/part_Sony_MDS-JE500+S37.html The page speaks of random retry errors. You might do better with a newer deck - they are not that expensive any more. Kind regards Quote Link to comment Share on other sites More sharing options...
Rezső Gubik Posted February 16, 2024 Author Report Share Posted February 16, 2024 I've read this topic too, but my issue is not connected with the titling of the disk/tracks 😕 Nevertheless, I hope I dont need to dump my deck... Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 16, 2024 Report Share Posted February 16, 2024 Right, but the existence of such errors does point to some underlying problem that is nothing to do with alignment. I don't think you can update firmware but maybe you (or someone reading this) knows differently. Quote Link to comment Share on other sites More sharing options...
Rezső Gubik Posted February 16, 2024 Author Report Share Posted February 16, 2024 Ok, its clear 🙂 Quote Link to comment Share on other sites More sharing options...
sfbp Posted February 16, 2024 Report Share Posted February 16, 2024 Stick around, we may need you (experts at fiddling with the low level stuff are always welcome around here). Do you live in Budapest? We had an excellent techy member from there who left us, sadly. Quote Link to comment Share on other sites More sharing options...
Rezső Gubik Posted February 17, 2024 Author Report Share Posted February 17, 2024 Dear sfbp, yes, I am from Budapest. I know an older repairman but in an other city. He will check my deck soon and I will come back with the outcome 🙂 Quote Link to comment Share on other sites More sharing options...
