Josiah Garcia Posted March 19, 2024 Report Share Posted March 19, 2024 hey im new to this forum so i dont really know how it works. anyway, i recently bought an mz e40 off of offer up. it was working perfectly. i went to walmart and yknow just did my day to day stuff. later that evening i came back home and put my disc in to listen to music but it said no disc. i figured it was just a dirty lens so i cleaned it with alcohol and popped in my disc again. it still didn't work. i opened it up and saw there was like some white gunk on the little spiral that moves the lens. i cleaned that off and put it back together the way it was. put the disc in still no disc. i have no clue what it is. i need help. please. Quote Link to comment Share on other sites More sharing options...
imkidd57 Posted March 19, 2024 Report Share Posted March 19, 2024 Hi and welcome to the SI forum! The basic 'No Disc' problem may be the sensor in the MD unit that tells it when a disc has been inserted after the lid is closed. It is a small black pin on the left-hand side of the MD base when the lid is open: This pin engages with one of the holes on the underside of the minidisc itself, and the pin gets pushed down when the minidisc is inserted and the lid closed: In older machines, this pin can become less sensitive and requires to be pushed down further. The malfunction can be associated with particular discs though. Do you have another to try? Otherwise you can test by putting a piece of sellotape over the pin to stick it down, then put the minidisc in and try closing the lid. If it reads the disc then you can assume it is the hole depth not being enough. I have overcome this problem by putting a tiny piece of paper into the hole of the minidisc itself, and pressing it down hard to flatten it within the hole using a small screwdriver. The effect is to raise the base of the hole and make it push that pin down a bit further when the lid is closed. Sadly, on some units the pin gets snapped off due to rough treatment and requires replacing. BTW, the 'white gunk' you saw on the spiral is lithium grease which is supposed to be there to lubricate the worm drive mechanism. If you cleaned off the excess then that's probably fine as there should be enough remaining in the thread to work. 1 Quote Link to comment Share on other sites More sharing options...
Josiah Garcia Posted March 22, 2024 Author Report Share Posted March 22, 2024 On 3/19/2024 at 12:31 AM, imkidd57 said: Hi and welcome to the SI forum! The basic 'No Disc' problem may be the sensor in the MD unit that tells it when a disc has been inserted after the lid is closed. It is a small black pin on the left-hand side of the MD base when the lid is open: This pin engages with one of the holes on the underside of the minidisc itself, and the pin gets pushed down when the minidisc is inserted and the lid closed: In older machines, this pin can become less sensitive and requires to be pushed down further. The malfunction can be associated with particular discs though. Do you have another to try? Otherwise you can test by putting a piece of sellotape over the pin to stick it down, then put the minidisc in and try closing the lid. If it reads the disc then you can assume it is the hole depth not being enough. I have overcome this problem by putting a tiny piece of paper into the hole of the minidisc itself, and pressing it down hard to flatten it within the hole using a small screwdriver. The effect is to raise the base of the hole and make it push that pin down a bit further when the lid is closed. Sadly, on some units the pin gets snapped off due to rough treatment and requires replacing. BTW, the 'white gunk' you saw on the spiral is lithium grease which is supposed to be there to lubricate the worm drive mechanism. If you cleaned off the excess then that's probably fine as there should be enough remaining in the thread to work. thanks so much i'll try it and get back to you Quote Link to comment Share on other sites More sharing options...
