djmalice Posted November 30, 2006 Report Share Posted November 30, 2006 Hi guys,is transferring music files to the walkman as 352kb atrac files from 192 to 320kb mp3 files doing anything to the audio quality of those files?I understand usually cross format encoding usually always results in lessening the quality Quote Link to comment Share on other sites More sharing options...
0 Ascariss Posted November 30, 2006 Report Share Posted November 30, 2006 best to just move over the mp3s. Quote Link to comment Share on other sites More sharing options...
0 navsimpson Posted November 30, 2006 Report Share Posted November 30, 2006 I'm guessing you're trying to save battery life, and I suppose transferring at 352 is the best you can do. Still, you're right - the audio quality of those files will be dropping. As Ascariss says, your best bet is to either just transfer them as MP3s or rip in ATRAC. Quote Link to comment Share on other sites More sharing options...
0 pata2001 Posted December 1, 2006 Report Share Posted December 1, 2006 is transferring music files to the walkman as 352kb atrac files from 192 to 320kb mp3 files doing anything to the audio quality of those files?I understand usually cross format encoding usually always results in lessening the qualityYes, not only you have lower quality, you wasted space for the larger file. If you already have MP3s, just keep them in MP3s. With 352kbps, you probably won't be saving much battery life either. Quote Link to comment Share on other sites More sharing options...
djmalice
Hi guys,
3 answers to this question
