blink-az Posted January 6, 2007 Report Share Posted January 6, 2007 hello guys, may i ask for your help?so, this is the story. i have sony walkman nw-a1000, but i lost my cd installer for it's connect player. i've already search that software in the entire internet. but i cant find it. There's only the auto update, but i dont have the connect player v1.0 so i cant update it. i also dont have internet connection in my house, so i cant use sonic stage.hmmm..could you please upload the file in some place, and then give me the link. it really help for me.~thx b4, sorry for my bad english Quote Link to comment Share on other sites More sharing options...
Ascariss Posted January 6, 2007 Report Share Posted January 6, 2007 You have no internet but you want be to upload the file someplace. o_O that is a bit well wierd, since if I upload it, you won't be able to download it anyways. Quote Link to comment Share on other sites More sharing options...
markey Posted January 6, 2007 Report Share Posted January 6, 2007 Why not see if your local Sony shop have a copy lying about that they can let you have, or you could allways try ebay. Theres allways some scum bag trying to sell various versions of sonic stage if you don't mind paying for it. Quote Link to comment Share on other sites More sharing options...
peter312 Posted January 7, 2007 Report Share Posted January 7, 2007 Have a look herecheersPeter Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted January 8, 2007 Report Share Posted January 8, 2007 *topic moved to its appropriate section of the forum Quote Link to comment Share on other sites More sharing options...
p0MTAh Posted January 18, 2007 Report Share Posted January 18, 2007 exacly the same thing happend for me , can't any1 create a image of the cd. // p0NTAh Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted January 18, 2007 Report Share Posted January 18, 2007 I will try and accommodate with its .iso in a few weeks time. Please check back accordingly. Quote Link to comment Share on other sites More sharing options...
aznbro85 Posted January 18, 2007 Report Share Posted January 18, 2007 Hey all, Just saw this post and decided I'll try to help. My friend helped me get a NW-A3000 from Hong Kong when he went back in January of 2006. It came with the CONNECT Player CD, which is version 1.0... I'm sure there's probably a newer version, but i believe with CONNECT Player you should be able to have it auto check for the newest version/add-on before the install...I decided to look for it, and i ISOed it and uploaded it to my online storage.Anyway, here's the link:http://amd.streamload.com/aznbro85/Hosted/CP10.isoHopefully this helps you (whoever that needs it) out! I probably will keep it here until March or so... If the mods of the forum want, feel free to grab it and upload it onto the ATRACLife Colloquium Download page. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted January 18, 2007 Report Share Posted January 18, 2007 Good Work :aznbro85:) Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted January 23, 2007 Report Share Posted January 23, 2007 Thanks for the assistance, aznbro85 I will consider hosting the .iso permanently at a later date. Quote Link to comment Share on other sites More sharing options...
pomj Posted July 5, 2007 Report Share Posted July 5, 2007 You can use the updatefile from sony. Unpack it and inside the 'files' folder you should start 'connect player.msi'. That's a full installation. Quote Link to comment Share on other sites More sharing options...
Channy Posted September 7, 2007 Report Share Posted September 7, 2007 Hi, (thought i'll revive this thread instead of opening another one)Well, I've lost my connect player cd too, and i need it for my a1000. Ive tried sonicstage, but it messed up my whole player (top100, corrupted all music).Can anyone upload a copy for me? Ive tried the link earlier on, but you need an account for it.Thanks. Quote Link to comment Share on other sites More sharing options...
pomj Posted September 7, 2007 Report Share Posted September 7, 2007 Go here:http://support.sony-europe.com/DNA/Connect...=NWH&f=AU03press the accept button and you will be downloading connect player. Use winrar (i've just tested with that) to unpack the installation file into a folder. Inside this folder start the file 'connect player.msi'. Works for me. Connect player will be installed and seems to be functioneing perfectly but I have no posibility to test an actual cyncing because my nw-a1000 is no more Quote Link to comment Share on other sites More sharing options...
Channy Posted September 7, 2007 Report Share Posted September 7, 2007 Just got home. I've downloaded the update file, extracted all the files out of it and ran the connect player.msi, installed it then rebooted the computer.Double-clicked on it, and all it shows is a blank screen.Gonna try searching for the cd around my bedroom. If i dont find it, theres a seller on ebay selling the cd's for £5.10, might just get one.Thanks anyways Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted September 8, 2007 Report Share Posted September 8, 2007 Just got home. I've downloaded the update file, extracted all the files out of it and ran the connect player.msi, installed it then rebooted the computer.Double-clicked on it, and all it shows is a blank screen.Gonna try searching for the cd around my bedroom. If i dont find it, theres a seller on ebay selling the cd's for £5.10, might just get one.Thanks anywaysI had uploaded the CD version awhile back. For your convenience:http://rapidshare.com/files/15137012/CONNE...rv1.0.part1.rarhttp://rapidshare.com/files/15133245/CONNE...rv1.0.part2.rar Quote Link to comment Share on other sites More sharing options...
Channy Posted September 9, 2007 Report Share Posted September 9, 2007 (edited) hey thanks! downloaded and installed fine.But it was missing a file in the installation folder, "ntmsapi.dll", went and searched for the file and found it on http://tinyurl.com/2l4b62, downloaded it into the install folder, and now it works fully.Thanks again Edited September 9, 2007 by Channy Quote Link to comment Share on other sites More sharing options...
