jakie Posted March 11, 2007 Report Share Posted March 11, 2007 My troubles all started today, when i went to upload some new tracks onto my NWA3000, using SS 4.0. The player froze and it told me to disconnect the player and reconnect. This didnt work so it said to delete all tracks, which i did, after backing up all the songs from it first.After installing the latest SS, i tried to import the backup library of songs, and most are bringing up the error message 'cannot convert the specific track'.There was about 3000 songs i backed up on to the harddrive, however nearly all of these songs were put on to my sony from my old computer...only about 300 tracks are on my new computer.Is this stopping it from uploading the tracks? So now i have my NWA-3000, with no tracks on it at all.....What can i do?Thanks Quote Link to comment Share on other sites More sharing options...
atown8605 Posted March 11, 2007 Report Share Posted March 11, 2007 I had a similar problem. It turned out that I was prematurely stopping the full loading of SS.The solution was to reload SS and wait until it completely loaded. It took a long time!Well over a half hour. Quote Link to comment Share on other sites More sharing options...
DanteSS3 Posted August 22, 2007 Report Share Posted August 22, 2007 I'm getting that exact same problem, rebooted my pc, went to add some new songs onto my walkman and bang the thing doesn't let me. I need to convert every single file inot a different format and then transfer it.I don't understand what you mean atown, do you mean leave it sitting on idel for about half an hour?Please, any help would be appreciated Quote Link to comment Share on other sites More sharing options...
