cool_rock Posted April 13, 2007 Report Share Posted April 13, 2007 well i want to ask that if accidently my walkman i mean nwe005 is connected to pc and power fails or pc shutdown does this damage the walkman. i live in pak where power failure is a major porblem. what to do.. Quote Link to comment Share on other sites More sharing options...
0 chupacabra314 Posted April 14, 2007 Report Share Posted April 14, 2007 cool_rock said: well i want to ask that if accidently my walkman i mean nwe005 is connected to pc and power fails or pc shutdown does this damage the walkman. i live in pak where power failure is a major porblem. what to do..As long as you are not putting any music on it during the power outage it is ok....You dont need to "Safely remove hardware" to pull it out (unlike the iPODs)....If the power shuts down during the moment you are uploading tracks, you will need to reset it or in some cases format it...Nonetheless you can't damage the player itself. Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted April 15, 2007 Report Share Posted April 15, 2007 cool_rock said: well i want to ask that if accidently my walkman i mean nwe005 is connected to pc and power fails or pc shutdown does this damage the walkman. i live in pak where power failure is a major porblem. what to do..Don't worry nothing will happen to your walkman .iin b/w How much did E005 cost you in Pakistan ? Quote Link to comment Share on other sites More sharing options...
0 cool_rock Posted April 15, 2007 Author Report Share Posted April 15, 2007 Stuge said: Don't worry nothing will happen to your walkman .iin b/w How much did E005 cost you in Pakistan ?well it is not availbale in pakistan and only core is available here its price is around 9000 rs for 1 gb and 1800 for nwa 800 or nwa 1200.well i guess the sony flash players are not available here. so i got it from usa.from one of my uncle. hm and it cost 100$ and i also want to ask that does removing it without safe remove or power faliure does the battery of walkamn is effected.. Quote Link to comment Share on other sites More sharing options...
0 cool_rock Posted April 15, 2007 Author Report Share Posted April 15, 2007 hiwell i ask this question with sony chat support they r saying that it iwll damaged the player.so i m confuse abt it. well i always remove my device with safe remove option.but still i m concern can u plz guide me the safe knowledge for mp3 Quote Link to comment Share on other sites More sharing options...
0 pata2001 Posted April 15, 2007 Report Share Posted April 15, 2007 chupacabra314 said: You dont need to "Safely remove hardware" to pull it out (unlike the iPODs)....If the power shuts down during the moment you are uploading tracks, you will need to reset it or in some cases format it...Nonetheless you can't damage the player itself.It is recommended to use the "safely remove hardware" feature for ANY USB mass storage devices. However, if you know that there are no data transfer going on (the E00x OLED screen will display the battery charging), then it should be OK to just hot-unplug it. And speaking of iPods, if you set the iPod NOT for disk use, it will automatically "eject" itself once you done syncing/transferring music in iTunes (you only see the "Do not disconnect" screen during music transfer/syncing). Quote Link to comment Share on other sites More sharing options...
0 cool_rock Posted April 16, 2007 Author Report Share Posted April 16, 2007 so u mean to say if i m not transfering any tracks or data to it. and if power fails or i remove it without safe remove it will not damage t he device. Quote Link to comment Share on other sites More sharing options...
cool_rock
6 answers to this question
