Salastico7 Posted May 27, 2007 Report Share Posted May 27, 2007 I thought that OpenMG is a Sony creation, and afterall i did rip the songs from the device onto the PC after i repaired my computer. So why is it not supporting them?ThanksSalastico Quote Link to comment Share on other sites More sharing options...
0 ender325_ Posted May 27, 2007 Report Share Posted May 27, 2007 Maybe it's because the songs that gets transfered to the player have Copy Protection enabled (happens automatically) which prevents playback if you drag them from the device to your PC and that's why SonicStage is not acknowledging them. Hope this helps! Quote Link to comment Share on other sites More sharing options...
0 Salastico7 Posted May 28, 2007 Author Report Share Posted May 28, 2007 ender325 said: Maybe it's because the songs that gets transfered to the player have Copy Protection enabled (happens automatically) which prevents playback if you drag them from the device to your PC and that's why SonicStage is not acknowledging them. Hope this helps!thanks very much mate, i did say that copyright 'may' be an issue but i didnt have a copyright problem before so dismissed it.Anyway around this problem anyone?thanks Quote Link to comment Share on other sites More sharing options...
0 Zizone_ Posted May 28, 2007 Report Share Posted May 28, 2007 I don't have an answer to this problem, but to prevent this issue being a problem in future, simply uncheck copy protection box when you are importing songs from CDs via SonicStage onto your computer. Quote Link to comment Share on other sites More sharing options...
Salastico7
Thanks
Salastico
3 answers to this question
