jackpott Posted June 13, 2007 Report Share Posted June 13, 2007 hey pls help i have been trying for 4 days to add some mp3 to my mp3 player but it says format errror also at first it has 1 gb capacity but now it has 970 mb pls helpp!!! Quote Link to comment Share on other sites More sharing options...
0 AntiPod Posted June 14, 2007 Report Share Posted June 14, 2007 try convert the songs into atrac through sonicstage, if the problem still exists, i suggest u to format the player in its menu, or by sonicstage. Quote Link to comment Share on other sites More sharing options...
0 RobA Posted June 14, 2007 Report Share Posted June 14, 2007 Did you try to drag the mp3 files to the player using windows explorer? If so that is the problem, you have to use sonicstage to transfer songs. Quote Link to comment Share on other sites More sharing options...
0 jackpott Posted June 14, 2007 Author Report Share Posted June 14, 2007 boys thx a lot for solving my first prob but second one still here i donno why it has 974 mb right now can i say pls help again? Quote Link to comment Share on other sites More sharing options...
0 RobA Posted June 15, 2007 Report Share Posted June 15, 2007 boys thx a lot for solving my first prob but second one still here i donno why it has 974 mb right now can i say pls help again?No player is truly what it is said to be. My HD1 is 20GB, yet started at 18.6GB. No 1GB player is really 1GB, it's normal. Quote Link to comment Share on other sites More sharing options...
0 Shinji Ikeda Posted June 15, 2007 Report Share Posted June 15, 2007 No player is truly what it is said to be. My HD1 is 20GB, yet started at 18.6GB. No 1GB player is really 1GB, it's normal.Rob A has it right...When it comes to flash or hard drive memory the numbering convention is strange. A 1GB player has 1,000,000,000 bits, which is not really 1GB (or approximately 107341800 bits). This is something that all manufacturers have done since atleast the introduction of the hard drive, may be even earlier.Take the size of your media player and divide it by the number of GB by 1024 three times. This should match the number of GBs. Quote Link to comment Share on other sites More sharing options...
jackpott
5 answers to this question
