bauks Posted June 25, 2007 Report Share Posted June 25, 2007 (edited) Hello!I hope, that I'm right here to enter my problem and hope for solution.I'm german so my english isn't always fine. I've bought a SONY NW-E003 and as I saw that here is a special SW necessary (SonicStage) I wanted to return it but thanks to VoidMP3FM my decision changed. I not used my player very often up to (had more work with searching alternative SW-solutions) now but I noticed no problems like described by other users here (e.g. when moving several directories).I've detected one fault: The showed playing-time is not correct. A song with 7min. is shown as ~3Min. When you playing a track you can see that 1 sec. on the display is really about 2-3 sec. running. The songs are playing complete and in correct speed. Player was already upgraded to V2.1.Many thanks for help or hints! Edited June 25, 2007 by bauks Quote Link to comment Share on other sites More sharing options...
lgm Posted July 29, 2007 Report Share Posted July 29, 2007 I have noticed this too, using NW-E015F. Quote Link to comment Share on other sites More sharing options...
DavidC Posted August 23, 2007 Report Share Posted August 23, 2007 Noticed it too. I like listening to an audio program that in total is 3 hours. I split it into 10 minute pieces so that I can quickly move from to a different part of the program. I noticed that if I try fast forwarding within a song it does not display the elapsed time correctly and seems somewhat slow fast forwarding. I had to reformat the drive and was adding some AAC files using sonicstage and did display the time correctly and the fast forwarding happened faster as well. Quote Link to comment Share on other sites More sharing options...
agniz Posted August 24, 2007 Report Share Posted August 24, 2007 yes, i also own a nw-e015f and the same happens to me. there are some known bugs but this software still is a great solution. I prefer use it instead of the Big White Elephant called SonicStage. In fact I am eager to get updated version of this VoidMp3fm. Any news or rumors?AgnizI have noticed this too, using NW-E015F. Quote Link to comment Share on other sites More sharing options...
