peterh321 Posted August 2, 2007 Report Share Posted August 2, 2007 i have no windows computer and really really want my nw a808 to work does the nw-e00x file manager work and also how do i get it to work if i just try dropping the player on it it dosnt work :(thanks Quote Link to comment Share on other sites More sharing options...
0 asadasad22 Posted August 2, 2007 Report Share Posted August 2, 2007 i have no windows computer and really really want my nw a808 to work does the nw-e00x file manager work and also how do i get it to work if i just try dropping the player on it it dosnt work :(thankswhat OS do you have? Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted August 3, 2007 Report Share Posted August 3, 2007 what OS do you have?I think he is using Mac ?I guess Quote Link to comment Share on other sites More sharing options...
0 Shinji Ikeda Posted August 3, 2007 Report Share Posted August 3, 2007 Their computer is definitely an non-MS Windows machine.Hello peterh321,Currently, files can be only loaded using SonicStage which is a Windows only software. It may be possible to use an emulator to run SonicStage on a non-Windows machine, but I do not know if this will be successful. Quote Link to comment Share on other sites More sharing options...
0 Zephir Posted August 4, 2007 Report Share Posted August 4, 2007 If you're using Mac, You can use bootcamp to emulate Windows and then install Sonicstage on that emulated Windows. Otherwise, I don't think there is any 3rd party software yet that supports the nw-a808 Quote Link to comment Share on other sites More sharing options...
peterh321
thanks
4 answers to this question
