Problems gettin video on to Sony NW 806
cooliojames
Sorry if this is in the wrong area - I couldnt find a better one - Im trying to use the video transfer thing that comes with the Nw 806 to put divx files onto the walkman the problem is it has to convert them which it does upuntil 99 percent and then tells me there was a problem with the file stream - anyone else had this know how to stop it. It happens with every DIVX file I try (but not normall AVI ones).
Thanks
3 answers to this question
Image Converter isn't the best software out there. I couldn't encode any .mov files. It sometimes works (good for xvid), it sometimes doesn't. I would suggest to make sure you have the proper codecs, or use other software that encodes to an iPod compatible .mp4 (eg. Xilisoft Video Converter is what I use) and it should be playable on your A806. Hope this helps.
