Nomak Posted December 13, 2007 Report Share Posted December 13, 2007 Hey Guys Again.1.How should i find out if my NW-A3000 is european or canadian? or w/e 5301122 (serial number) if it helps2.Does hack work on Firmware 3.0? 3.Is it possible to downgrade?4.Should i press keys fastly after eachother when inputing hack "code" or they just need to follow in order?5.What's the way to get the max sound out of player?Thanks for the time! Quote Link to comment Share on other sites More sharing options...
0 juli_ Posted December 14, 2007 Report Share Posted December 14, 2007 Nomak said: 5.What's the way to get the max sound out of player?Thanks for the time!I think some recently asked this exact question!Try this: http://www.anythingbutipod.com/archives/20...imit-unlock.phpThe member who unlocked theirs did it really easily and quickly and said it made a noticeable difference. No reason why it shouldn't work for you too Quote Link to comment Share on other sites More sharing options...
0 Ascariss Posted December 14, 2007 Report Share Posted December 14, 2007 Canadian models of the A3000 and A1000 were never volume limited. If you have european model, then you will need to hack the volume, volume hack will work on firmware v 3.0.Can't downgrade, I wouldn't bother with that, since the new firmware adds wma and fixes bugs. Just follow the rules for unlocking, if slow doesn't work, try it faster until it loads into service mode.as for highest volume, volume hack and then setting volume to 30, but I wouldn't recommend 30 , too loud. Quote Link to comment Share on other sites More sharing options...
Nomak
Hey Guys Again.
2 answers to this question
