tbenschop Posted June 16, 2008 Report Share Posted June 16, 2008 Is there a way to forward tracks faster? When playing a 2 hour mix it takes about 10 minutes to get to the half of the track.... 10 minutes and a sore thumb.. Quote Link to comment Share on other sites More sharing options...
0 juli_ Posted June 16, 2008 Report Share Posted June 16, 2008 tbenschop said: Is there a way to forward tracks faster? When playing a 2 hour mix it takes about 10 minutes to get to the half of the track.... 10 minutes and a sore thumb..I think if you press 'pause' first - and then hit f/f, it will go a LOT faster. Quote Link to comment Share on other sites More sharing options...
0 ender325_ Posted June 18, 2008 Report Share Posted June 18, 2008 juli said: I think if you press 'pause' first - and then hit f/f, it will go a LOT faster.To the topic starter, no, that is one of the main weaknesses of the jog dial walkman. And to "juli", no, if you do that you'll skip the song. You're referring to the players after the S70x series. Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted June 19, 2008 Report Share Posted June 19, 2008 yeah ,thats one of the negatives of A7xx series Quote Link to comment Share on other sites More sharing options...
0 juli_ Posted June 19, 2008 Report Share Posted June 19, 2008 Ooops sorry. My 706 has been retired to the speaker cradle and only gets used on there. I assumed it had the same f/f feature as the 808. Quote Link to comment Share on other sites More sharing options...
0 tbenschop Posted June 25, 2008 Author Report Share Posted June 25, 2008 hmm.. That's what I was afraid of.. So no firmware upgrade or something that could fix this? Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted June 26, 2008 Report Share Posted June 26, 2008 tbenschop said: hmm.. That's what I was afraid of.. So no firmware upgrade or something that could fix this?well,NO Quote Link to comment Share on other sites More sharing options...
0 imagine_ Posted June 26, 2008 Report Share Posted June 26, 2008 The FF is way faster than the E400/E500 series which were excrutiatingly slow (basically, ff at the same rate as the file normally plays). Unless you are dealing with 30 minute tracks, its not that slow, I am ok with it. I remember that the A600 (the one between the S700 and the E500) had an option in advanced options to accelerate the FF (up to 8x i believe), but this one does not. Quote Link to comment Share on other sites More sharing options...
0 iroczvinnie Posted June 29, 2008 Report Share Posted June 29, 2008 (edited) Thinking out loud here but I recall back in the day that my aiwa md unit could split atrac tracks on the unit it self. This got me thinking - I don't know anything about your player series, but if you are using sonicstage you can divide tracks if they are atrac/pcm (per atrac help). You could divide the track into 2minute segments and This would allow you to skip to approx where you want to start. Yay for atrac :-) Edited June 29, 2008 by iroczvinnie Quote Link to comment Share on other sites More sharing options...
0 tbenschop Posted July 2, 2008 Author Report Share Posted July 2, 2008 Too bad it's mp3.... But thanks for thinking/helping! Quote Link to comment Share on other sites More sharing options...
tbenschop
9 answers to this question
