NetMG help files not in english, also MD not recognized
Guest Anonymous
Guest Anonymous
I have a SharP MT880 Minidisc with OpenMG Jukebox software. The interface is ok yet the help files are in japanese. How can I get a version where the help files are in english.
Also, my Sharp 880 is not being recognized in my OpenMG Check in/check out or the Device/Media windows. I can get it to recognize all my other hard drives etc. Do you have any thoughts on this??
Thanks,
Ernie
enadams@movementpathways.com
heyy there,
um u could d/l the english version of openmg here : http://www.minidisct.com/forum/showthread....=&threadid=8654
i fink dat mite work but not 2 sure u can check it out...and as Leland has said try re-installing the driver 2 c if it helps...otherwise start openmg without plugging ur netmd in and then when ur in the Check In/Check Out tab plug ur unit in2 the USB n c if it can become recognise...if not then i suggest u re-install the drivers dat'l b ur best bet...
