OpenMG with Win XP Pro
Guest Anonymous
Guest Anonymous
Anyone know of any problems with OpenMG Jukebox and Windows XP Pro? I have installed this but XP just crashes when Jukebox starts. It is the same with simple burner. Any ideas.
Thanks
David
  • 3 weeks later...
I use it with XP Home, no problems. Also have it on a Windows 2000 Professional based system, no problems. (note: "no problems" means it works but freezes up occasionally due to the buggy nature of the software.)
Did you find the patch to OpenMG Jukebox on the Sony support site and install it? You might try that.
