Please Don't Discriminate Because I Don't Have A MZ-N1.
edgeman
When you plug the USB cable into the MZ-N505 recorder, does it fit in tight, or can you jiggle it around a little bit? I tried putting some songs on a disc and OpenMG couldn't find the player, so I checked to see if it was connected tightly, and it moved the socket. The cable fits into the socket fine (I think) but it seems that the socket is loose inside the body of the player. It doesn't move a lot, just a little, but I don't know if it'll get worse. Are they all like this or is mine defective?
