krymson Posted January 31, 2003 Report Share Posted January 31, 2003 I have some internet radio shows i downloaded ( car talk) that I like to put on my minidisc. Currently I'm using LP4 recording, but is there a way to get Mono LP2 or 4? Let me see, that would be about 10 hours with the lp4 rite? Quote Link to comment Share on other sites More sharing options...
me Posted January 31, 2003 Report Share Posted January 31, 2003 Impossible. Quote Link to comment Share on other sites More sharing options...
Bazirker Posted February 1, 2003 Report Share Posted February 1, 2003 to reconfirm what "me" said, the md player doesn't allow lp2 mono recordings while lp4 mono is impossible. while lp2 records in stereo, lp4 does not; it uses a different type of recording called joint-stereo. it takes the similarities between the left and right channels and rather than encoding them twice (once in each channel,) it just records them as one channel. In a way, it compresses the stereo imaging. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 10, 2003 Report Share Posted February 10, 2003 I'm interested in the comments about stereo recording in LP4 mode. Where did this information come from. I'm listening to a MD recording made in LP4 and I'd swear it's true stereo! Quote Link to comment Share on other sites More sharing options...
Daijoubu Posted February 11, 2003 Report Share Posted February 11, 2003 Quote I'm interested in the comments about stereo recording in LP4 mode. Where did this information come from. I'm listening to a MD recording made in LP4 and I'd swear it's true stereo!LP4 is Joint-Stereo! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 3, 2003 Report Share Posted October 3, 2003 i was always creating mono SP recordings before but now with netmd, i don't see the option is it possible to transfer in mono SP format? Quote Link to comment Share on other sites More sharing options...
mAjEsTiC Posted October 4, 2003 Report Share Posted October 4, 2003 Quote i was always creating mono SP recordings before but now with netmd, i don't see the option is it possible to transfer in mono SP format?i don't think so...because i havn't found an option which will allow me to do so... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 4, 2003 Report Share Posted October 4, 2003 Bazirker, from your description, I think it's a safe guess that LP4 uses Intensity Stereo rather than the more common Joint Stereo (which is a combination of Mid/Side Stereo and True Stereo as you call it (L/R Stereo). Quote Link to comment Share on other sites More sharing options...
clonmult Posted October 6, 2003 Report Share Posted October 6, 2003 LP4 is joint stereo, in EXACTLY the same way as MP3 encodes it. On most regular pop music, you can't tell the difference between "true" stereo and joint stereo. I'll try and put my Ali Demeola guitar stuff onto Lp4. I doubt it'll cope. Quote Link to comment Share on other sites More sharing options...
daxuwei Posted October 14, 2003 Report Share Posted October 14, 2003 Yes, Mono mode is same with LP4 in recording time, 'cause LP4 is joint-stereo, so a 80 MD could only record 320 min data. Quote Link to comment Share on other sites More sharing options...
