imparanoic Posted July 17, 2009 Report Share Posted July 17, 2009 how do you get cover art without using wmp11?, just realised i can not get wmp11 as i have pirated copy of windows xp, is there any other way to import cover art to a nwz-x1050, thanks Quote Link to comment Share on other sites More sharing options...
0 bob123 Posted July 17, 2009 Report Share Posted July 17, 2009 If the album art is tagged to each song then putting songs on the player by drag n drop will work. Using WMP11 is no differnt. If the songs didn't have album art in their meta data (or whatever its called) then art won't show up on player even if wmp is used. there is software out there that allows you to do that - one is audio shell - think that is free - but does take a while to load all art on - other members may know of a quicker way ??? Quote Link to comment Share on other sites More sharing options...
0 jimbo Posted July 19, 2009 Report Share Posted July 19, 2009 I use Mp3tag to add album art to my music. It's a simple program which is really easy to use to organize your music.It's called embedding the album art in to the ID3 Tag of the songs. As long as the art is 500 x 500 or below (I think, although I have a feeling I have some over that) and the size is below 100kb, then you can embed it in your songs and it will display succesfully on your X-Series. Just embed the art and use windows explorer to drag-and-drop your music onto the Walkman.You can download Mp3tag here: http://www.mp3tag.de/en/ Quote Link to comment Share on other sites More sharing options...
0 hpilot Posted August 10, 2009 Report Share Posted August 10, 2009 I use Mp3tag to add album art to my music. It's a simple program which is really easy to use to organize your music.It's called embedding the album art in to the ID3 Tag of the songs. As long as the art is 500 x 500 or below (I think, although I have a feeling I have some over that) and the size is below 100kb, then you can embed it in your songs and it will display succesfully on your X-Series. Just embed the art and use windows explorer to drag-and-drop your music onto the Walkman.You can download Mp3tag here: http://www.mp3tag.de/en/Yes, this is a great program. I use album art at 600x600 with no problem (most Amazon songs are 600x600). I have about 4000 songs - all tagged perfectly. I guess I just don't get why most people don't spend the time to do this... Quote Link to comment Share on other sites More sharing options...
0 tds101 Posted August 10, 2009 Report Share Posted August 10, 2009 Also, try either J.River Media Jukebox (it's the free version), or Media Monkey. Both work great for tagging and album art. J.River is the more uesr friendly, and MM is the advanced program. I use J.River myself. Quote Link to comment Share on other sites More sharing options...
0 Kbadone Posted August 15, 2009 Report Share Posted August 15, 2009 Just to let yo know guys, WMP12 does not work good with WAV files I tried using it where it does not tag cover art and artist name to the WAV file. WMP11 does it fine. Maybe a firmware upgrade might fix the problem Quote Link to comment Share on other sites More sharing options...
0 Wiwa Posted December 15, 2009 Report Share Posted December 15, 2009 Hi, I am experiencing a problem regarding cover art on my NWZ-X1050. I've added covert art to all of my songs, but all covers look unsharp (it looks blurred, because the resolution isn't right, I guess) on my NWZ-X1050. Nearly all images are 500x500, which seems pretty standard to me. Is there any way to solve this problem? If not, I'd rather not have any cover art at all than very blurry cover art. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
0 lacobo Posted January 15, 2010 Report Share Posted January 15, 2010 Hi, I am experiencing a problem regarding cover art on my NWZ-X1050. I've added covert art to all of my songs, but all covers look unsharp (it looks blurred, because the resolution isn't right, I guess) on my NWZ-X1050. Nearly all images are 500x500, which seems pretty standard to me. Is there any way to solve this problem? If not, I'd rather not have any cover art at all than very blurry cover art. Thanks in advance! Was experiencing the same issue when I used the software delivered with the walkman. I wrote to Sony about the problem and they had no solution (the software seems to be made for the A8X8 walkman, which had a smaller screen and a lower resolution). Then I started using Windows media player and that went Ok, but a bit complicated. A few day's later I started browsing for answers and found a recommendation to "Mediamonkey". This is an ideal piece of software. Covers can be added manually (I use 200 x 200 pixels for the NWZ-X1060) or downloaded automatically. Synchronizing the songs to the 1060 is very easy and it's possible to convert songs to a less space-consuming quality. I found the program so easy to use that I bought the gold version (life time updates for 30 dollar or something like that). Now the pictures look sharp on the 1060 and it's very easy to fill it with my favorite songs. Bert. Quote Link to comment Share on other sites More sharing options...
imparanoic
7 answers to this question
